Gigabyte Radeon RX460 Screen Resolution Problems
hetr94
15
Hello.
I recently bought a Gigabyte Radeon RX 460. I installed it on my computer, and it all seem to work out fine. After that, I used the CD it brought to install all the necessary drivers. It installed Gigabyte Xtreme Gaming Engine and also Radeon Settings (version 16. something). After restarting my computer, the screen doesn't fit, even if I select any resolution that appears on the list. I updated Radeon Settings to 17.4.4 (latest one), but I still have this issue. The screen looks awful and it doesn't fit.
Specs:
Operating System: Windows 10 Home 64-bit
Processor: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz (4 CPUs), ~3.3GHz
Memory: 8192MB RAM
DirectX Version: DirectX 12
Radeon(TM) RX 460 Graphics 4Gb GDDR5
Motherboard: Asus P8H77-I
Monitor: Samsung SyncMaster P2370HD
Thanks for the help!
Is the resolution set to 1080 on the TV? Try using another input type. Did you try the auto configure option?
hetr94
15
Hey! Thanks for the quick reply.
I just connected my PC to another TV (also Samsung) and it displays perfectly in a 1366x768 resolution. What can I do to connect my PC to the other TV that is giving issues?
At least I'm glad it's not a video card problem
hetr94
15
I will try that. I'm not sure how to do it, I will have to check on the internet about my TV settings, but as soon as I do it I will keep posting. Thanks for the quick replies!
