I am from india my budget is 1.7k rupeesgood and cheap are mutually exclusive things in terms of PSU. so not possible.
what's the budget?
where are you from?
Hey guys i just need proper solution not a suggestion like getting a new psu .....
the problem is i have a 550 w all 30 A no company PSU and it does not have a 4 pin or 6 pin and i want to power my 760.
can i use molex to 6pin + 6pin to dual 6pin
2k-3.5kFirst you need to specify your budget. Under 1.7K INR it's not possible to get a decent quality PSU.
That's not a good PSU. The newer CX models like the CX550 I suggested are decent the older CX models(which were discontinued awhile ago) like the CX 600 are not good. Hopefully you can still cancel it or return it.Thx got a cx600
Depends on what type of "cheap" your definition is 😉good and cheap are mutually exclusive things in terms of PSU. so not possible.
I brought it for 2.7k Packed ...That's not a good PSU. The newer CX models like the CX550 I suggested are decent the older CX models(which were discontinued awhile ago) like the CX 600 are not good. Hopefully you can still cancel it or return it.
Free would have still been overpriced.I
Thx got a cx600
