[SOLVED] GPU and CPU Permorning lower than expected
It tells you the reason for low performance/benchmark score: Very high background CPU (61%). High background CPU reduces benchmark accuracy. Find active processes with Windows task manager (CTRL+SHIFT+ESC).
Your build performs good, but Windows is busy with something and using CPU while you're benchmarking.
Open 'details' in task manager and sort by CPU to see what's using up your processor in background. Give it time and watch if this usage is constant, then it's abnormal.
