Question GPU and monitor compatibility ?
tschultz
5
Howdy,
I have the following:
Monitor: ASUS VG278 (might be VG278HE)
GPU: AMD Radeon RX 6650 XT
The problem is I have the monitor connected to the GPU by HDMI cable. Via HDMI the monitor can only output 1080p@60hz. (you can see that here right at the bottom).
With my previous GPU I could connect via DVI-D and run at 144hz.
Is there any solution to get 144hz with my new GPU ?
Would a connector from the GPU (HDMI/DisplayPort) to monitor DVI-D work?
It might be a possibility since the DVI-D monitor output supports 144hz, but maybe that would be lost by the conversion cable?
Best Regards,
Tom
