Hi! So, if you can look pleae at he image here: Slots
My new computer came installed with the ssd and gpu on the circled slot areas, but there is another slot for gpu and another for ssd (both pointed in the image). The ssd contains the OS.
So, my question is, should I change any of them into the other slot available? Does it make any big difference, or should I just leave it like this? And if I should, can I just do it myself or will it require some reconfiguration on the bios or something like that? (I probably won't be able to re configure myself)
The mother is Tuf Gaming x750 plus, the cpu is Ryzen 5 3600, the ssd is a SN500 NVMe (PCIe) 250gb , the gpu is an old Sapphire R7 240 1gb
THANK YOU SO MUCH!
THANK YOU SO MUCH!
