So basically recently I bought a second hand GPU(ASUS RX 580 8GB DUAL FAN) and second hand PSU(500w some korean company called NewZen), and noticed that I've been getting massive FPS drops in games.
Previously I had a 1050ti 4gb, which was also a second hand one and I had no fps drops with it, the PSU was different too a 400W one and it was new. So had to switch to a 500W because of the cables so went for a cheap option to buy a second hand 500W PSU.
Thought it was my old 16mb cache hard drive so I changed it to a new seagate hard drive, got less fps drops but it was still there.
I just wanted to know if im experiencing the fps drops because of the GPU or the PSU so I can replace. I'll post down a benchmark for Far Cry 5 and MSI Afterburner monitoring graphs below. You can notice the GPU Power drops significantly when the FPS drops occurs along with the GPU clock speed.
p.s temperatures are fine, i know many will say its because of the temperatures and the clock speed drops to cool it down, but you can check the graphs the temps are fine.
Also I want to know if the GPU power dropping during gameplay like that is normal or not, because it drops from 150w to 5.7w when the fps drops.
Specs:
i3-8100 3.60 GHz (new)
H310M S2P 2.0 (new)
8GB Ram (new)
Seagate Baracuda ST1000M010 1TB (new, where game/windows is installed)
Seagate ST500DM002 (16mb chache one, old)
ASUS RX 580 8GB Dual Fan (second hand)
NewZen 500W PSU (old, second hand)
Benchmark:
View: https://youtu.be/pt6dC6efpLg
Graphs: View: https://i.imgur.com/hhd9qa0.png
Specs:
H310M S2P 2.0 (new)
8GB Ram (new)
Benchmark:
