[SOLVED] GPU fan not Spining
Apr 1, 2021
Hi
I own a GTX MSI 960 GPU. Recent i am seeing that gpu fan is not spinning. When i boot up the pc its spin for 10/30 sec then stop spinning. While gaming gpu temp goes upto 90°c but fan don’t kicks in for cooling. Tried to change it speed with msi afterburner but nothing happen rpm always at 0. Is my gpu fan dead or any other issue?
You might want to inspect the GPU's connectors and perhaps the area around the GPU's fan connector. It's possible that the power isn't going to the fans. On that note, might want to have a case fan pointing at the GPU to work as a stop gap.
