Hello, I have been facing an issue over the past few weeks.
GPU: RTX 2080 Ti
When I use 3D software like Unreal Engine or Blender, the GPU doesn't maintain a consistent speed. Instead, it suddenly peaks at maximum speed for a few seconds before returning to normal.
I can't find a solution using MSI Afterburner, as the RPM seems to be entirely independent of the settings.
I try to explain:
If I set the the fan speed at
30% the RPM is 1548 -
60% the RPM is 3003 RPM -
100% the RPM is 5007 - Screenshots below
Now let's jump on the issues:
You can see the RPM jumped to 5317 twice for few seconds while the fan speed is set is a 30% and it's a flatline, no peaks shown
same here, RPM at 5321 for few seconds but the fan speed is set at 65% doesn't show any changes
Afterburn controls the fan speed but not the RPM. What can I do to fix this issue, and what could be causing it?
Device name OMEN 30L Desktop - GT13-0024nl
Processor Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz 3.60 GHz
Installed RAM 64.0 GB (63.9 GB usable)
Power supply
Internal PSU 750 W
Total wattage: 750 W
Full range: 115 V/230 V
Efficiency: Platinum
GPU: RTX 2080 Ti
I try to explain:
Power supply
Internal PSU 750 W
