Question GPU fan speed showing "N/A" under load ?
Hi, I was looking at the settings on my 5700xt and noticed that my fan speed was showing as N/A. I put it under load and still shows N/A. The fans are spinning. I also checked with HWinfo and it says the same thing. How do I fix this?
Ryzen 7 5800x
Powercolor 5700xt
ASUS TUF gaming X570 plus
32GB DDR4 @ 3600MHz
View: https://imgur.com/a/zrBV8t6
How about the GPU and HotSpot temps?, are this two OK when runing games ?
Did you installed the latest GPU driver from AMD website?
