[SOLVED] GPU Noise // Boost Clock
Sep 25, 2019
11
Hello all, A little background: I do a lot of 3D rendering, mainly GPU based. I recently bought 2x ASUS RTX 2080TI cards. One is very quiet and the other makes a high pitched noise. I've had coil whine before but this seems higher pitched and is constant. The sound only goes away while rendering with a normal clock. I did some testing with the included Asus gpu tweak software and found if I cranked the GPU boost clock way up to 1800 mhz + manually the sound goes away when I'm not rendering. However, if I go back to my 3D software and hit render the application crashes. It's getting frustrating constantly having to change the clock settings and the sound is driving me nuts. Should I return it? Will having it cranked to 1800 mhz damage the gpu? Is there anything else I should try? Any suggestions would be greatly appreciated. Thank you.
Ps: I'm rocking a 1300 W power supply that I've never had issues with.
Thank you for your response, that makes sense. I've uploaded a video as well to demonstrate the noise:
View: https://vimeo.com/362319479
That sounds like one of the fans to me- as a quick check you can try manually stopping each fan on the gpu one at a time by gently applying pressure to the central hub until it stops- you'll probably find one of them is causing the noise. That probably explains why applying an overclock helps- if you increase the temps the fan rpm will go up (I find fans start to fail at low rpm and slowly get worse over time).
A constant high pitched whine on one card? That is definitely faulty (especially if the other card doesn't do it). It doesn't sound like coil whine, maybe a bad bearing on one of the fans? I'd get the card replaced asap (just don't mention anything about overclocking in your support request).
