Question Gpu overheat Help!!
viglenali0
Commendable
May 21, 2018
Hello I have a
650 watt psu
Gtx 670 and Gtx 580
I5 2500s
8 RAM
Hello, I have 4 fans in my pc 1 at the bottom front, the back top near psu and 2 case fans. 1 of my case fan that is suppose to be cooling my GPU stopped spinning I was planning on replacing it until I read something that said 1 case fan wouldn't effect temps that much. Idle both gpu sits at 50-65 and when I play a game even on the lowest quality gpu using no usage at all it increases by 1 degrees every second until it reaches 102 degrees. From there I off my pc(using msi afterburner to check temps). I've also been running my fans at max speed even when pc is idle and I get as I said 50-65 degrees. I really need help i cant play anything without losing frames because once my gpu hits 100 degrees the usage goes up even when I am playing a game that requires no graphic at all. Do I replace my case fan that blows my gpu ? My cpu temp is at 50 when gaming but my gpu sky rockets. :c
