Question GPU qled sometimes on, no monitor output
JunkSniperJoe
61
5
545
Every 3 to 5 times I power on my pc, the gpu qled light comes on and nothing is output to my monitor. All connections to the psu seem okay, and everything else connected to the mobo is recognized and working as intended (so far). I'm assuming the gpu is busted, but I thought I ask here before sending it in for an RMA.
PCPartPicker Part List: https://pcpartpicker.com/list/MnZnqp
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard
Memory: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3600 CL18 Memory
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive
Storage: Samsung 980 Pro 1 TB M.2-2280 NVME Solid State Drive
Video Card: MSI GeForce RTX 3080 10 GB GAMING X TRIO Video Card
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case
Power Supply: SeaSonic FOCUS Plus Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Update: Sent pc to Microcenter repair, since I had a protection plan on the gpu. They're saying no issues where found after 7 boots into the BIOS and multiple test in Windows to check for component stability. This leads me to believe the monitor is the issue. I'll try out my newer monitor with a direct dp connection. If that fails, the psu may be the problem.
