First off, i have been lurking here for years, this is my first post though, love all the help i get from here without even posting anything, also my teacher uses this website for our A+ class, so here is my problem, now that i am done with my rant.
I got this system over the weekend: basic components V
AMD Athlon II X3 3.6GHz 435
Asus M4A77TD PRO
4GB DDR3
500GB Sata II Hard Drive
HIS Radeon HD 4670 IceQ / HDMI out
I used the Asus unleash feature to unlock the fourth core to a AMD Phenom(tm) II X4 B35 Processor [codename propus] (no l3 cache unfortunately, but that's not the problem)
It boots up perfectly but it seems to have killed the graphics card in the process. well not killed but i get fuzzy images and yellow pink and blue lines across pages, i would post a screen but im on a different PC.
SO i set the BIOS to the default settings, re locking the 4th core. I rebooted and the problem went away.
So i figured it was my PSU re-enabled the 4th core and lowered the multiplier down to x4 making it around 2.9GHZ, the problem persisted after that still. I still think it might be a problem with insufficient power, either that or my fourth core is actually faulty, i can live with that, but for the sake of knowledge i would like to deduce what the problem is.
Right now it is back to the default 3 cores @ 3.6GHz and running perfectly
Edit: my PSU is 450W so i am going to throw in a 700W when i get home tonight to see if that might be the problem.
Edit 2: my graphics card was also overclocked using AMD Overdrive. (do no remember exact settings at the moment)
Asus M4A77TD PRO
4GB DDR3
