[SOLVED] h100i gtx not cooling.
Feb 14, 2019
5
I've recently upgraded my pc from nearly the ground up, (old cooler though) I haven't booted windows yet but I'm having problems with my CPU temperature.
I'm using a liquid cooler (Corsair h100i gtx) from my old build. The cpu fans are not registering on the BIOS but they are spinning and all LED lights are on, within 2-3 minutes of starting cpu temperatures hit 90. Not sure what to do.
CPU is 9700k
Thermal paste applied
Motherboard is Gigabyte Aorus pro wifi.
UPDATE
After installing a stock cooler and getting the same temperature readings I decided to install windows to get a second opinion which gave temperatures of about 50. I then installed my cooler and temperatures are now sitting at about 30 when idle.
This pump only draws power from the CPU header which is connected, tried different headers. I believe I've identified that the pump isn't moving the liquid, radiator stays cold and I can feel heat in the tubes but only close the the CPU.
https://www.gigabyte.com/Motherboard/Z390-AORUS-PRO-WIFI-rev-10#support-manual
page 17
CPU_OPT (Water Cooling CPU Fan Header)
The fan header is 4-pin and possesses a foolproof insertion design. Most fan headers possess a foolproof insertion design. When connecting a fan cable, be sure to connect it in the correct orientation (the black connector wire is the ground wire). The speed control function requires the use of a fan with fan speed control design.
UPDATE
