Hard drive issue
Tom
1,720
Archived from groups: microsoft.public.windowsxp.general (More info?)
Using Windows XP pro, the hard drive is showing in the Bios when pc boots
up, but then a message disc boot failure and no further
Any suggestions on what the problem is and advice on how to overcome would
be appreciated
Tom
A fail hard drive may still be detected and show up in the bios. Doesn't
mean that it will work properly!
Regards,
Richard Urban
Microsoft MVP Windows Shell/User
Quote from: George Ankner
"If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!"
"Tom" <Tom@NoSpam.com> wrote in message
news:%23DeCWrjtFHA.2328@TK2MSFTNGP10.phx.gbl...
> be appreciated
> Tom
> be appreciated
The fact that the BIOS recognizes the presence of the hard drive
doesn't mean that the hard drive isn't defective. After checking to
ensure that the hard drive's connections haven't worked loose, and that
the IDE controller hasn't failed, try replacing the hard drive.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
Tom, it could be that you have a floppy in the flop drive and it's set
as first boot device in Bios. Or, it could be a failed
hard drive if you havent done anything unusual or it could be a loose
connection or defective ribbon cable or power
connector.
> be appreciated
> Tom
Repair console from XP boot CD. Repair boot sector. If unsuccessful in
booting again, try repair mbr.
> be appreciated
> Tom
