I have a pair of headphones with two 3.5mm jacks, they allow me to listen to audio from two different sources at once.
I also have a KVM (sort of) that lets me switch between my work computer and home computer at the click of a button.
My goal:
To be able to listen to audio from my work computer (jack 1), while being able to listen to audio from home computer (jack 2) at all times regardless of which PC is active (via my KVM).
Here is a diagram of how things are setup. I've left out everything pertaining to HDMI since I don't think it's a factor here and it will just complicate things, but do note that while my setup seems a bit odd, it is because of the way my monitors are setup.
As you can see there's sort of a loop situation going on where my home pc has a connection via both the docking station and directly to the headphones via line out. The result is that I get a constant static noise if both jacks are connected. Changing the output settings on my home pc between usb and line out works, audio comes through both channels separately, but the static is always there so long as both are plugged in. Unplugging either cable will remove the static.
Is there some sort of one-way noise filter that I can plug in that will eliminate the noise? I found this in a search, will it do any good if I plug it straight into my line out from my home pc? Or is there something more common that I don't know about that will solve my problem.
Any and all comments are appreciated. Thanks in advance!
My goal:
