Hi to everyone reading this.
PC SPECS :
-r9 290 reference
-fx 8350 with a Noctua NH-U9B cooler
-asrock fx 990 extreme 3, the motherboard
-Thermaltake Chaser A41 is the case
-1 top fan exhaust 200mm, 1 front fan 120mm intake, 1 bottom fan intake 120mm 1 rear fan exhaust 120mm.
Ok, so, the problem is i have this pc for a year now, and i've always had problems with temps. I know the reference r9 290 is not the best choice and it heats to 94 degrees. The ambiental temp in my room is ~89F, or ~31C. I know it's hot, but still, the CPU reaches 68 at 30% playing TERA for instance. I've tried everything in terms of airflow, i even stuck a 200mm fan to the wall to blow to the side of the PC. It seems to be even warmer when i close the case, so i leave it opened.
Idk what to do other than go water, but still, is it normal to be 68 degrees at 30% ?
PC SPECS :
-r9 290 reference
