Hei , I have problem with my CPU , can you help me!!
groph
4
Hei gays , sorry i speak so bad english but i try to tell you for my problem.
I have these components on my pc :
CPU: i5 760 2.8GHZ
RAM : 16GB RAM KHX1600C9D3B1K2/8GX Kingston HyperX 2x4GB, DDR3 1600MHz, CL9
HDD : "2TB
GRAFIC: NVIDIA Geforce Gt 630.
Motheboard : ASUS P7P55D-E PREMIUM
But if i put normal mode, without overclocking doesn't work, always he restarted. It doesn't go to DESKTOP.
But if i put Overclocking exp. 2.9GHz or 3.02 Ghz or 3.6 Ghz then it work's , he can goes at desktop but it doesn't work properly. It doesn't work well.
So Can you help me!!!!!
Maybe This has something to do with windows itself;
Maybe you should try to reset overclocking settings to default and enable all the processor features on the BIOS screen, things like 'execute disable bit' and other special features.
If the problem still persists, there's a slight possibility that the hardware went bad because of the overclocking. Are you using the stock cooler for OCing or do you have a different cooling system?
In the Bios at Overclocking page I put at Crazy CPU 3.0GHZ or 3.66GHz then the pc start working and i can go to desktop but if overclocking on at default settings the pc doesn't work well it's mean the pc restarted all the time. When the Windows logo coms after that pc restarted and started from the beginning.
in this video you can see my bios i was found on the youtube this video.
http://www.youtube.com/watch?v=ncMI8HUD0hE
