HELP CPU UPGRADE FOR MY ASUS A8N-SLI PREMIUM
cruzkntrl
24
CAN SOMEONE PLEASE TELL ME IF I CAN UPGRADE MY CPU WITH AN INTEL, I HAVE THE ASUS A8N-SLI PREMIUM AND THE AMD Athlon(tm) 64 FX-53 Processor (2412 MHz). I WOULD LIKE TO UPGRADE SOME THING BETTER FOR HD VIDEO EDITING. PLEASE HELP. THANKS. PLEASE NAME 3.
The quick answer is "No". You would need to change out your motherboard for one that is Intel based. The A8N-SLI Premium will only accept AMD CPUs that fit socket 939. Have you thought about overclocking or getting a dual core processor? I'm currently running an Opteron-180 dual core(2.4gHz) in mine.
cruzkntrl
24
Hey clarkjd, check out my configurations and tell me what do you suggest my best upgrade or two?
Processor: AMD Athlon(tm) 64 FX-53 Processor (2412 MHz)
Operating System: Microsoft Windows XP, 32-bit (Service Pack 3)
DirectX version: 9.0c
GPU processor: GeForce 8800 GTX
Driver version: 180.48
Stream processors: 128
Core clock: 576 MHz
Shader clock: 1350 MHz
Memory clock: 900 MHz (1800 MHz data rate)
Memory interface: 384-bit
Memory: 768 MB
Video BIOS version: 60.80.07.00.11
IRQ: 18
Bus: PCI Express x16
Sorry, I just now saw this question. IMHO you have pretty much maxed out your system. You could get a dual core processor, but socket 939 CPUs are hard to find and more expensive than they are worth. I would suggest looking at going to the Intel I7 or AMD Phenom II setups with DDR3 ram. (Course that means new MOBO, CPU, and ram.) Also look at getting a new 64bit OS. You should be able to reuse any optical and hard drives and your Video card and sound card.
Good Luck!
mamw93
540
No. Completely different sockets and everything. No way it will even physically fit in the same board. Get the Phenom II and be happy.
en sabah nur
4
I have just been given a Amd socket AM2+ athlon64 x2 Dual-core 7750 Black edition Processor, will this work in the ASUS A8N-SLI Premium? I am currently running a Single Core Processor 2200Mhz.
en sabah nur
4
Hey there, can you tell me if this (AMD Athlon 64 X2 4800+ Processor Socket 939) will work on the The A8N-SLI Premium is a socket 939 motherboard?
Korbu
I have a question, do you know what the latest video card that supports A8N SLI Deluxe motherboard soket 939 ..?
