Question Help for My First build
May 1, 2019
9
I actually have a build in my mind
CPU: Ryzen 5 2600/2600x
CPU COOLER: Stock Cooler
MOBO: Msi X470 gaming plus/
B450 Gaming Pro Carbon AC WiFi
STORAGE: 120 GB M.2 SSD
1 TB HDD
RAM 16gb 3200mhz Trident GSkill
650w psu tx650m
Coolermaster master case mc500
Is it overkill for for 1080p gaming at very high to ultra ?
I can't decide a GPU for it though.
$1000 to 1200$ max budget with Monitor etc
Thank You
This will largely be decided by your GPU - but as of current. no it isn't. You could always consider a 1660 ti / 2060 for example.
Just remember that your M2 shares bandwidth with a SATA port, so it disables one of your SATA ports if the M2 is populated.
Be sure to opt for 2x8GB as opposed to 1x16GB.
Reactions: Adialex_K
