[SOLVED] Help identifying system crash (Event id's)
xllGARYllx
4
After 15 minutes or so of my system being stressed via gaming it wil crash, Loud static noise in my headphones then total freeze. I have to restart my system by holding the power switch.
What could cause this? It does not crash if im playing a low stress game (Civ 5) or desktop browsing. My temps are all fine.
Event IDs: View: https://imgur.com/a/YCcWiIh
Specs:
Windows 10
GTX 980 Strix
i5 4690k @ stock
16gb 1866mhz Hyper x
MSI z97 Gaming 5
cx750 Corsair psu
The only errors you might want to look at there are the critical ones
Every PC on earth seems to get DCOM errors so I would ignore those
if you are crashing with no BSOD, it might not show anything in event viewer as windows may not be aware of problem.
Have a look in Reliability history, it may show you more. It sees a restart using the reset button as a hardware error. Just so you know.
