Question Help me choose
egzon12
Commendable
Aug 15, 2019
23
Which motherboard is better for a ryzen 5 3600:
ASUS PRIME B450-PLUS
ASRock Fatal1ty B450 GAMING K4
ASRock B450 PRO4 - AMD B450
GIGABYTE B450 AORUS PRO
MSI B450 TOMAHAWK MAX
ASUS TUF B450-PLUS GAMING
ASUS ROG STRIX B450-F GAMING
ASRock B450M Steel Legend
Im gonna be overclocking, and do i need to do a bios flash and can it be done without cpu, cuz I dont have one?
Thank you in advance.
and do i need to do a bios flash and can it be done without cpu...
Of all those, only the Tomahawk MAX can you be confident does not need a BIOS flash. Every other one would also need a different CPU as you can't flash them with a Ryzen 3000 CPU.
As it so happens it's also one of the best, if not the best, for overclocking. Not that you should, but that's another post.
