Help me find a case!
stevenlikesfishing
71
I would like a case thats under $100 (rather like it under $75) it needs to have the cable management thing so you route cables to the back (like rubber groumets or the cut out holes). and i would like it of good quality.
heres what i was looking at
COOLER MASTER RC-692-KKN2 CM690 II Advanced
thanks
That case you chose will have holes for cable management, but if you want the rubber grommets it will be more than 100$
some other good options:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197- $89.98 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 - $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196 - $89.99
Cooler Master cases have great quality and any of these cases will have good cable management. It comes down to personal preference
You can't tell from the Newegg pics but it has a top cut-out the same size as the bottom one.
Also it's hard to see the open space that runs the entire case height between the mobo plate and drive cages.
It's open beside the FP and case cables that are tied in the pic.
The 690 does lack a cpu cut-out which isn't a huge deal if you choose an aftermarket cooler and mount the back plate before installing the mobo.
I would second the LIAN LI case, though the HAF 922 and your first case are great choices. As case is a personal decision, so get what you like and what looks good to you with the required features you are looking for.
I just updated from an original Antec 1200 to the Corsair 650D and couldn't be happier. I'll use my Antec 1200 for a secondary build down the road.
