I have a very old design Silverstone FT-02 case and recently installed an RX 6800 XT Video Card that I now can't return (bought on Newegg). I still prefer this case due to the superior air cooling design. Unfortunately I had to remove one of the fans at the bottom to get it to fit inside the case. I should be able to fit a Silverstone SST-FW181 or SST-FM182 case fan there if I can find any for sale. Does anyone know where I might be able to order one of these Ultra Slim design fans?
If not, do you have any other manufacturer suggestions? It will need to be 180 mm size for a drop-in replacement, and 18 mm height is ideal, the current 32 mm fan is too tall. If none exist on the market, I wonder if there is a way to adapt my case to fit a smaller 120 mm ultra slim fan, since I have found some of those on the market. Note that I don't want to lose the dust filter at the bottom, I would consider that mandatory for this pc case to work.
aerocooler.com
Here are some pictures of the installed video card inside my case:
https://ibb.co/1dfkNNc
https://ibb.co/mCCg0Lq
Silverstone SST-FM182 180x180x18mm Super Slim Speed Control 180mm Fan
