[Help] PageFile in same Drive (Dual Boot XP & Vista)
sevendp
74
Hi....
I have 2 HD, 1 HD got 2 partition, XP (C:) and Vista (D:), the other HD (E:) for swap file,
Can I set pagefile on both windows in same drive E: ??? (pagefile.sys on same drive).
i havent try it yet........
usually I set pagefile both Min and Max to 1786MB (my Ram is 2 GB).
is that OK?
If i disable pagefile what affected by this (XP and Vista)? performance or got some error?
thx
dp
if you disable pagefile the worst that can happen is the bsod then you can start and enable it if you see your pc can't handle it 😉
