Question HELP PLEASE ASUS VG248QE DVI NO SIGNAL
Jul 31, 2019
6
I recently bought the nzxt starter pc and i have an asus vg248qe and when i plug in the dvi port it says no signal. but when i plug in an hdmi cable into the gpu it works fine. i want to play at 144hz but with hdmi it limits me to 60 please help me i am new to this pc stuff lol. (there is noi dvi slot on the gpu)
what the gpu?
better yet, what is the full system spec
AMD Ryzen 5 2600 6-Core 3.4GHz
NVIDIA GeForce GTX 1660 - MSI GAMING X
Team T-FORCE Delta RGB 16GB (2 x 8GB) 3000MHz
Intel 660p 512GB
MSI B450 TOMAHAWK
Seasonic S12II 500W Bronze
AMD Wraith Stealth Cooler
NZXT H500 (White)
The Ryzen 5 2600 has no igpu so the ports on the motherboard are useless. The GTX 1660 has Displayport as does the monitor so you'll need a displayport cable to get 1080@144hz.
Ok thank you i was freaking out for about 20 minutes lol. do you know if they sell display ports at stores or can you only order them online??
