Need help desperately.Have a 1.3 AMD with a GFORCE2 PRO-64 meg and my flight sim starts out well at around 100 frame rates but as the action heats up drops all the way to 4 frame rates.Something is terribly wrong,no way this system should drop off that much.Have the latest DX8 installed do you think I should go back to DX7?Everything has the latest drivers.Iam at a complete loss as to what is slowing and chokeing this thing down.I also have Cacheman installed and Windows manageing the memory with the swap file on C drive along with the operateing system.Nothing is running in the backround,use Enditall to make sure.Any help and ideas will be greatly appreciated.HELP ME PLEASE!!!!!!!!!!
System Spec's
Computer-Alienware-rebuilt
CPU-AMD Athlon-1.3GHz-family-6 model-4 stepping-2 MMX enabled
M.B-MSI-K7T-Turbo-MS-6330-v3.0
BIOS-Phoenix Tech-02/21/01
Chipset-KT133A-latest 4 in one drivers
Maxtor HD=7200 rpm
384-meg pc 133
Hercules Prophet II-GTS Pro-64 meg- Det beta 11.01 drivers
Aureal Vortex 8830 sound card
NEC MuliSync 19in monitor
Saitek controls-USB
1024-768-32-res
85MHz-refresh
Win98se
DirX8.1a
System Spec's
Maxtor HD=7200 rpm
384-meg pc 133
Saitek controls-USB
1024-768-32-res
85MHz-refresh
Win98se
DirX8.1a
