Help with Audio issues
Chala
125
When playing music on my computer the sound skip's, stutters and pauses. I have these symptoms when playing a
CD as well as MP3 files . I tried different players but all have the same result. I thought it was my Anti Virus, but
when disabled it symptoms still occur. When I exit all applications with the exception of the software playing the
file it's much better and skipping, stuttering and pauses are almost non existent but still happens.
I now disabled the sound card and went to onboard sound, and a half hour in it's working flawlessly. Is this a bad sound card? Please Help!
OS: Windows Professional
Processor: Processor 3.20 gigahertz Intel Celeron
RAM: 2048 MB
Hard Disk 1TB of which 15GB is used
Sound Card: Sound Blaster Audigy-Model Number SB0570
The Audigiy SE are really bad sound cards most onboard sound will be better then that card. For sound cards anything really under $70 will not be much better then your onboard sound if its better at all. If you really want a quality sound card Look at ASUS Xonars or an HT|OMEGA Striker the Sound Blaster X-FI Titaniums are really good cards too but you are gonna spend atleast $80 on a decent card if you dont got that to spend on one just stick with onboard sound.
LOL
I thought i updated the right drivers, but i may be wrong and having a problem with obtaining the correct drivers. I am using Windows XP Pro.
SAAIELLO probably the best advice i have gotten, thanks for that piece of information
Popatim tell me more about IRQ issues and where to begin to troubleshoot if you know. I just updated to the latest driver below. Using Windows XP Pro.
Unable to post the link here for some reason, but it's the Creative Sound Blaster Audigy Value/SE/LS and Sound Blaster Live! 24-bit XP and Windows Vista Pack 1.04.0077
