I made a list with all the parts that i am going to buy for my new desktop computer. List:
When I check the parts for compatability i get the following warning and notes:
1st: Warning!Some AMD B450 chipset motherboards may need a BIOS update prior to using Matisse CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
2nd: Note:The motherboard M.2 slot #1 shares bandwidth with SATA 6.0 Gb/s ports. When the M.2 slot is populated, two SATA 6.0 Gb/s ports are disabled.
3rd: Note:Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders.
My questions are:
Thanks in advance!
CPU | AMD Ryzen 7 3700X |
CPU Cooler | Scythe Ninja 5 |
Motherboard | MSI B450 TOMAHAWK MAX |
Memory (RAM) | Corsair DDR4 Vengeance LPX 2x8GB 3200 |
Storage - SSD | ADATA XPG SX8200 Pro NVME 1TB M.2 SSD |
Video Card | Sapphire Radeon RX 5700 PULSE |
Case | be quiet! Silent Base 601 Orange Midi |
Power Supply | Cooler Master MWE Gold 550 Full Modular |
My questions are:
- Is it needed, with this motherboard specifically, to update the BIOS? I've read multiple websites and they say different things.
- What does the 2nd one mean? Is there a problem in this particular build/set-up?
- I've read that the CPU cooler is very large. Combined with all the other parts, will it fit in the desktop case?
Thanks in advance!
