Question Help with modding an HPE ML350 GEN9 TOWER server for quiet home use ?
scodrot
I've got a HPE ML350 GEN9 Tower server which is fairly quiet during the winter. Like, my laptop and PC are louder than it. During the summer however, things are getting out of hand.
There are two areas that are problematic. These happens to be the VR P1 location at the back of the case - behind of one of the processors. Google says this would be the "Voltage regulator processor 1 zone ". The other one os the RAID controller, which is expected to be running hot.
Once the temp in the room goes over 25 degrees (C), the fans go wild just to cool down these components, causing more noise.
I am seeking advices how to cool this down, as the fans of this chassis are located at the front. I've been thinking of buying two 40mm Noctua fans and swapping them to the RAID controller passive cooler & CPU passive cooler with zip ties, but I don't think I will find a 12v slot to power it up with. Perhaps a USB (5v) fan would also do the work - I can plug it in the first USB port or power it with a regular phone charger. That way, there will be an active cooling way behind in the system, getting more air flow through that area and getting the hot air out of the case faster. Another thing I will do is relocating the PCIE network card out of that area (it happens to be right in the hot area) and placing it way down.
My main question is, what are my options for connecting the fans to the motherboard, as these server systems aren't really designed to run with anything else but what has been sold by HPE. Can I even connect another 12v or 5v component (fan) to it? If yes, how?
Here's a pic I found on Reddit, which shows the internals. The main differences is that I've got a single PCIE device (network card) and I'm running all 4 fans:
This is a homelab server, but the chassis is not easily reachable and I want to gather some opinions first before spending a few hours of just getting into the opening the box.
Any tips and recommendations are welcome, thanks.
Looking up the specifications the only additional fans mentioned are the redundant installation so I'm guessing the only connections available would be those. Looks like there's a proprietary connector for powering the fan cage.
I can't think of any way to do PWM type control, but you could look for a fan hub/controller that was powered and didn't require motherboard fan connection. The last one of these I had was from over a decade ago and I think it used molex, but I'd imagine you could find a SATA powered one.
Reactions: scodrot
Thanks. The thing is, this server uses SAS ports and it has just SFF cables free at the moment. I don't trust molex much, and the system is supposed to run 24/7 anyway. I'm really locked in here
Well it comes down to what power connectors might be available and given that it's a fully integrated OEM server you're likely limited. Looking through the specs it seems like anything power related was an addon so you're really limited to whatever is there now.
USB powered fans are certainly a thing (5v fans can potentially just be adapted), but I'm not really sure how easy a routing job that would be unless the motherboard headers aren't in use. The manual wasn't st all clear on that, but if they aren't you could use a header to USB port adapter.
Is the server actually RAID?
Is RAID really necessary?
For most current environments RAID is not necessary.
Making the proverbial "leap of faith" here but if RAID is not a requirement then the RAID controller may have little or nothing to do and all may be cooler.
Is there any way to test with RAID disabled and check the temperatures and heat map thereafter?
If not RAID then the idea is moot - no harm in asking....
Latest posts
