Hello.
So I have an 10700K that I've decided to overclock to 5.0.
The problem is that the voltage seems to be too high in my opinion, or maybe it isn't, I don't know, that's why I am here.
I've used BIOS self overclock where it says two options, Gaming Profile which is +1 and Advanced Profile which is +3 (+0.3)
But I've noticed that the temps go up to 92C on a CPU STRESS TEST as shown Here:
92C
up to 1.440V
So what I decided to do is this instead, what do you guys think? is it safe and will I be fine?
After I did this, the temps and voltages are as follows:
From 92C to 85C and this with CPU Vcore Auto -> Normal, Dynamic Vcore Auto -> -0.100V
Are those fine and should I keep those settings as is? Thanks!
