Help - XP Pro - Partition problems
ICFire
9
So I updated the bios on my Asus A7M266 and it went w/o a hitch.
...until I rebooted
...after rebooting OS told me I had a corrupt file (though it didn't say which file, just where it was). I tried sticking in the CD to repair...but before I got to that screen it would bsod on me...
I finally got it to boot in safe mode.
Then I got it to boot in normal mode...all is good....not
Now my storage partitions are "unknown paritions" and they all were ntfs partitions.
I have a 100G and 40G hard drives in this unit. 100G is my boot drive...boot partition is 40G, then I have another 40G partition on it. I have a 2nd 40G drive in it that's divided into 2-20G partitions. ALL partitions except the boot partition are now known as "unknown" partition.
Any suggestions?
ICFire
try this
boot up with the WIN-XP cd go into repair mode and than into recovery console... now type "fixboot" and than when it asks u a question answer "yes" now when thats done type "fixmbr" again the same procedure.. i think this should work else letme know... will try to help
THE MAIN CAUSE FOR GLOBAL WARMING- MY KICK ASS ATHLON XP 😉
Thanks, I'm going to try that.
Stupid question time - I set my own account up as administrator...and have forgotten my true administrator pw.
....workaround for this little snag?
ICFire
<A HREF="http://www.computerproblems.com/kenscolumns.cfm?ColumnID=136" target="_new">What can I do if I forgot my password in Windows XP?</A>
I hope you created a password recovery disk.
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
______________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
