Heroes 3: The Shadow of Death - help running program in XP
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.strategic (More info?)
I installed Heroes of Might & Magic 3: The Shadow of Death last night
-an upgrade from the standard Restoration of Erathia, but I have been
unable to find a way to run the program under Windows XP with SP2. I
tried the various compatiblity settings under the properties for the
executeable to no avail. I still receive an error message whenever I
attempt to launch the game. Has any one had success in getting HoMM3:
SoD to run under XP with SP2? I had HoMM3 plain running earlier but
perhaps I've overlooked some technique I used to get it running in XP.
Any tips on what you've done to get either SoD or RoE to run would be
appreciated.
best regards, mat
np: The Wipers - Is This Real?
www.pdxshows.net
On Fri, 18 Mar 2005 13:08:20 -0800, Vader des Vaderlands
>appreciated.
It runs fine on my P4 with XP Home and SP2, but I don't remember if I
had to do anything special or not because it has been a while.
Henri
> appreciated.
I found myself in a strange situation where the game wouldn't install
under Win2K and the patches wouldn't install in WinXP. So I installed
it under WinXP and ran the patch programs over a network from a Win2K
machine. Annoying, but it worked.
This has a suggestion for WinXP:
http://ntcompatible.com/cdetail10395.html
Other messages (for Win2K) suggest that there is a problem with the
CD-ROM copy protection.
Send mail to fadden@fadden.com (Andy McFadden) - http://www.fadden.com/
CD-Recordable FAQ - http://www.cdrfaq.org/
CiderPress Apple II archive utility for Windows - http://www.faddensoft.com/
Fight Internet Spam - http://spam.abuse.net/spam/ & http://spamcop.net/
>>appreciated.
Odd but good that it worked out for you!
It turns out that was the problem I was experiencing as well. I was
able to get the game running by applying a no-CD patch. Cheers!
best regards, mat
np:
www.pdxshows.net
