Hibernation problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
A strange problem occured on my new machine. After I put it into
hibernation, everything looks ok. Then, when I boot the sistem and the logon
screen appears, I cannot enter into my account. My password isn't recognized
(I get a friendly "Did you forget your password" message:) After normal
restart, all works well. Why does this happen? I'm running WinXP SP2 Prof.
Thanks.
G
Guest
Guest
Hi,
Dumb question, but are the capslock and numlock keys in the right position?
Sometimes they will become disabled after hibernate if they are normally in
the "on" position. It is also possible that your keyboard driver is not
properly supported under hibernate and is not returning the right character
set when you resume. In the latter case, an updated driver may help, and may
not. Sometimes, hibernate simply will not function correctly on some
hardware combinations.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Danijel" <danijel.tomasicMAKNIOVO@hi.t-com.hr> wrote in message
news:d3b2rk$kf7$1@ss405.t-com.hr...
>logon screen appears, I cannot enter into my account. My password isn't
>recognized (I get a friendly "Did you forget your password" message:) After
>normal restart, all works well. Why does this happen? I'm running WinXP SP2
>Prof.
> Thanks.
