Hide Icons does not work
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hi all,
I just got my new computer up and running from Dell. XP Professional with
all their garbage included, lol.
I note that it does not matter if I toggle the 'Hide Icons' block on or off,
the Icons do not hide.
I have the ones that always stay and if something is opened or notifies, it
appears in the Icon task bar area, but they are always in full view.
Each Icon's behavior is set to Hide when not in use.
The Task Bar does not even change configuration (ie: there is never the left
indicating arrow circle) between checking hidden or not hidden.
Is there something I can check on, or is there a fix that any one knows about?
Many thanks.
Hi,
It takes some time for Windows to determine the inactive period of a icon
and then hide it. More info here:
Why don't my Notification Area icons show or why do they disappear?
http://www.kellys-korner-xp.com/top10faqs.htm
Anando
Microsoft MVP- Windows Shell/User
http://www.microsoft.com/mvp
http://www.mvps.org
Folder customizations
http://newdelhi.sancharnet.in/minku
Protect your PC!
http://www.microsoft.com/protect
"Lexus" <Lexus@discussions.microsoft.com> wrote in message
news:AAB4FC0A-EF9C-45F6-BBC7-B7C2D3B2B10E@microsoft.com...
> Hi all,
> off,
> it
> left
> about?
> Many thanks.
Thanks for the links.
I noted several things that I would like comments on pls.
1) I am the only user and did not set up a password, so my system
automatically signs on from the Welcome screen to the desktop - is this a
problem?
2) While my 'Hide Icon' tabs are not greyed out, Kelly has a fix for that
which I looked at -- the reg file entry for 'EnableAutoTray' shows DWord 1,
my registry shows the value as 0. Is this the problem even though my tabs
are not greyed out?
Thanks again.
"Anando [MS-MVP]" wrote:
> Hi,
> Anando
> http://www.mvps.org
> Protect your PC!
> > Hi all,
> > off,
> > it
> > left
> > about?
> > Many thanks.
The information provided from Anando, gave you the info needed. A quick
recap:
For some users, setting the very first icon to Always Hide, restores the
arrow (chevron).
All the Best,
Kelly
Microsoft-MVP Windows® XP-Shell/User
2004 Windows MVP "Winny" Award
Troubleshooting Windows XP
Taskbar Repair Tool Plus!
http://www.kellys-korner-xp.com/taskbarplus!.htm
news:A8FA5EC3-C305-4E6B-ABD0-1913F0D02540@microsoft.com...
> problem?
> 1,
> are not greyed out?
> Thanks again.
>> Hi,
>> Anando
>> http://www.mvps.org
>> Protect your PC!
>> > Hi all,
>> > with
>> > off,
>> > notifies,
>> > it
>> > left
>> > about?
>> > Many thanks.
Kelly thank you very much for your response. My first Icon is already set to
always hide, but no luck in restoring the arrow (chevron).
So before I start running some of your other fixes, could you pls comment
regarding the 2 items that I mentioned to Anando.
1. Should I create a passworded user rather than my current no password? If
that does not help, how can I take the password out?
2. Although my hide icon block is not greyed out (conditions for 1 of your
registry fixes), my registry entry for EnableAutoTray is set to DWord 0.
Should I set this to 1?
Many thanks again.
> recap:
> arrow (chevron).
> All the Best,
> Kelly
> > problem?
> > 1,
> > are not greyed out?
> > Thanks again.
> >> Hi,
> >> Anando
> >> http://www.mvps.org
> >> Protect your PC!
> >> > Hi all,
> >> > with
> >> > off,
> >> > notifies,
> >> > it
> >> > left
> >> > about?
> >> > Many thanks.
Hi,
You dont need to create a passworded user account. You can try setting the
DWORD to 1 and see what happens.
Anando
http://www.mvps.org
Protect your PC!
news:0EEFBF1D-B46B-4421-A2E0-000A28F25CC2@microsoft.com...
> to
> If
> Many thanks again.
>> recap:
>> arrow (chevron).
>> All the Best,
>> Kelly
>> > a
>> > problem?
>> > that
>> > DWord
>> > 1,
>> > tabs
>> > are not greyed out?
>> > Thanks again.
>> >> Hi,
>> >> icon
>> >> Anando
>> >> http://www.mvps.org
>> >> Protect your PC!
>> >> > Hi all,
>> >> > with
>> >> > or
>> >> > off,
>> >> > notifies,
>> >> > it
>> >> > the
>> >> > left
>> >> > knows
>> >> > about?
>> >> > Many thanks.
