HMMMMM....A LITTLE HELP WITH INFECTED FILES!
HonestJhon
2,333
Alright, i have norton anti virus 2002, and it found a sub7...
i got rid of that, but just to be sure, i ran the check on the system volume information...
and it found some infected files in the system restore files.
what i am wondering is, can i delete these files, seeing as how they are "uncleanable".
if they are restore points, wouldnt i be able to delete them, and then create a new restore point?
USING WINDOWS XP PROFESSIONAL.
quick help would be great!
thanks in advance!
-DAvid
-Live, Learn, then build your own computer!-
hmm
found out that norton skips those files when it scans....weird...
anyone know if it is safe to delete them tho?
i would like to be able to go to sleep knowing that there arent any detectable viruses on my computer......
-DAvid
you can delete the restore folder, but of course then you wont be able sto do a system restore- of course you wont want to in this case! disable system restore or it wont let you delete the folder.
If they squeeze olives to get olive oil, how do they get baby oil?
after i delete the files, can i make a new restore point?
like with no viri?
thanks for the info BTW! :smile:
-DAvid
awesome...
gonna do that now..
also, should i just delete the files through norton, or should i search for the file, and delete it?
man, i feel like a newb with this...lol
-DAvid
weird, weird, weird...
i found some restore information on my d partition, which is not where xp is installed...
hmm..and it is infected with the virus...
assuming that i can delete this?
-DAvid
ok, i cant delete them, because they are in use?????/
weird.
how would i go about making them not in use?
like how can i pause the system restore?
-DAvid
I guess Norton didn't find all the virus. Is this right?
<font color=red>Remember...</font color=red><font color=blue>You get what you pay for. :smile: All advice here is free.</font color=blue> :wink:
Go to site below and let it check your hard drive.
<A HREF="http://www.pcpitstop.com/antivirus/default.asp" target="_new">Virus check</A>
well the thing is, i had a sub 7 thing on my computer...but i deleted it....i knew it was a sub7, because my little brother was trying to hack into his friends comp or something....
but the file was just on my computer, not ran on my computer, and i guess windows backed it up.....and now i cant delete the files that have the backed up virus because they are in use...
i cant even delete them manually...
i will let that site scan my computer...
i had to let norton include the system volume files in order for it to pick up the backed up files...
<A HREF="http://housecall.antivirus.com/housecall/start_corp.asp" target="_new">http://housecall.antivirus.com/housecall/start_corp.asp</A> picked it up....but couldnt delete them.
all i need to know is how to go about removing the backed up files.the files that it is finding are in the system volume information on my d partition...
where it is apparently putting the restore points...because it logged my last program install in a text file in there.......
-DAvid
De-activate system restore; Delete system restore folder on all partitions/hard drives; Re-activate system restore; Set new restore point.
alright...where do i deactivate it...
i am still learning all the tricks in xp...
but funny thing is..the pc pitstop thing didnt catch it...
it probably doesnt scan sensative windows files like that....
norton doesnt by default...
-DAvid
never mind...i found a way to do it...lol
in the system restore itself...and if i turn it off there, it deletes the previous restore points....and then i assume that if i enable it, it will make a new one by itself..
but i am scanning with norton one more time.
if it finds it still, i will do this.
-DAvid
OMG>>>>EVERYTHING IS GONE!!!!!!!!!!!NOOOOOOOOOOOOOO!!!!!!!!!
heh....just kidding...the only thing that is gone is the virus...
no more!
yay!....celebration time...
now i go get a glass of water..
thanks for the help everyone!
-DAvid
you know it.
weird that i couldnt just delete the files...
i guess that the monitoring thing just keeps those files active, so that every little change, it logs, and then if something goes wrong, and i need to go back...it will be able to...
-DAvid
It is handy to take a snapshot just before you install new software,
drivers and so forth. It they mess up your system you can just roll
back to where you were.
yeah, this windows xp thing is becoming less and less elusive...hehe.
but yeah, i think me had a feature somewhat like this, but man, i didnt even use that os long enough to need it...
i think i used me for a day or so, and then BAM, everything went south, and i lost everything.
but i have used the xp driver rollback on my old server...kinda cool....
-DAvid
Glad you sorted it, sorry I couldnt re-reply, wasnt by pc all weekend
