Question How and where to connect case-fans?
Elliah246
BANNED
Feb 11, 2024
165
6
585
How do you do it?
Would you recommend connecting case fans to the headers mounted directly on the case, or connect the fans to the motherboard?
What even is the difference?
An important factor is ramp-up time. As soon as your cpu temp begins to increase the supporting case fans speed should increase to provide airflow for the cpu cooler or AIO radiator cooler fans. This is best accomplished by connecting the fans to the motherboard and setting the bios to control them. If the wattage power required by the fans is low enough you can split each motherboard connector 2 or 3 or 4 ways to support the number of fans in the case.
Headers on motherboard are regulated by motherboard.
Headers on case might not be regulated at all. This depends on pc case and fan hub used.
The case would be the antec flux or antec flux pro.
Nevertheless your reply suggests that connecting fan headers to the mobo is the safer option?
The pro case would have a total of 6 fans while to non pro would have 5.
In both cases 3 fans would be mounted sideways to throw in cold air, those 3 fans should they be split into one and connected with a single header or no? If yes would one have to buy a fan split header or would this be most likely included with the case?
Sounds good!
So it isnt enough to just connect the fan headers to the mobo but also it must be configured in bios or will there be auto-configuration but you might be able to create a better fan curve manually?
Edit: the mobo would be the ASUS ROG Strix B850-E
The fan controller that comes with the Pro case manages the PWM functions of the fans. That controller will actually use one of your motherboard PWM headers. So you won't need to connect a bunch of fans directly to the motherboard.
How will the fan controller of the pro case use one of the mobos headers? Is it me connecting them both with a cable? Does the non pro work the same way?
Your motherboard has 5x chasis fan headers
plus CPU_OPT and AIO_PUMP header. Those also can be used for chasis fans.
You know, you can download user manual for your selected pc case and familiarize yourself with installation and case fan setup.
Page 32 shows fan hub. You can connect up to 5 fans to the fan hub.
https://www.antec.com/documents/product/case-240627_Antec_Flux Pro_Manual_compressed.pdf
Yes, there will be a cable that runs from the controller to be attached to one of your motherboard headers.
I haven't looked at the non-Pro, but if it has a similar controller it would work the same way.
Alright, so probably the manual of the motherboard will explain which header the fan should be connected to?
Could you elaborate fruther, the AIO_PUMP is ment to be connected to the radiator right?
Whats cpu_opt? Yes i am able to see the manual but not fully understand all its content.
Will you be using AIO liquid cooler?
AIO_PUMP header is meant to be used for AIO PUMP. You could have guessed that from the header name.
But if you do not intend to install AIO liquid cooler, then AIO_PUMP header can be used for a regular chasis fan also.
CPU_OPT header is meant for second CPU cooler fan.
Some air cpu coolers have single fan. Some larger cpu cooler models may have two fans.
Thanks for explaining
According to the manuals for that mobo you have no CPU_OPT header. The ONLY header that controls things according to temperature measured inside the CPU chip is the CPU_FAN header, so THAT is where you must attach the RAD FANS. The PUMP of your AIO cooler system should be plugged into the AIO_PUMP header right next to that. Then you MUST configure that AIO_PUMP header correctly using BIOS Setup. If you do not yet have the manbual for the mobo BIOS system, get it here
https://dlcdnets.asus.com/pub/ASUS/mb/13MANUAL/E25269_AMD_800_Series_BIOS_manual_EM_WEB.pdf?model=ROG STRIX B850-E GAMING WIFI
On p.6, Section 2, see how to Enter BIOS Setup. Then proceed through the menu system to reach the AIO_PUMP header section on p. 100. On most AIO system the design intends the PUMP to run full speed all the time, so you MUST set the item "AIO Pump Profile" to FULL SPEED. (Use of this header for FANS in other systems requires a different setting.) when you have finished your changes use the F10 key to reach the EXIT Menu (p. 113). There choose Save Changes and Reset.
As mentioned above in other posts the CASE vent fans are to be connected to the mobo CHA_FAN headers at the bottom edge, perhaps using the fan hub. Those headers are guided by a different temp sensor on the mobo.
Were you looking at the wrong manual perhaps?
