Hello!
Very confused with all this and I'm desperately trying to figure out what should connect to what and which way around etc. Each Powerline adapter has 2 ports on it. So one to a node, another to a switch? Or one to the node and one from the node to the switch? Or one to the switch and one from the switch to the node? Etc.
Office:
I have an ISP modem in Bridge Mode, meaning only one of its ethernet ports is useable. A cable goes from there, to a Linksys Velop node (which is acting as the router).
Unfortunately, the nodes only have TWO eth ports on them! Obviously one of them is being used as the link to the modem. The other has my personal laptop connected into it.
I have 2 laptops in my home office; my work laptop and my personal laptop. Both need ethernet. My personal laptop is used to connect to a cloud gaming platform, so that's why it goes directly into the router to try and minimise interference / lag etc.
The work laptop is plugged into a little TP-Link 8-port switch. There's also another cable going from there into a Powerline adapter about 6 inches away.
Kitchen:
The Powerline adapter is paired to another one downstairs in the kitchen which is plugged into another Velop node and there's another cable from the node into another switch, which has my Hive Heating plugged into it.
Lounge:
Then... there's another Powerline in the lounge with a Nintendo Switch, TV, Apple TV, PS5 and Chromecast plugged into it.
If it makes it easier, it looks like this...
Upstairs (Office)
Modem > Node > Laptop
Work Laptop > Switch > Powerline 1
Downstairs (Kitchen)
Powerline 2* > Node* > Switch > Hive (*Note: this node and Powerline are what is feeding the work laptop upstairs)
Downstairs (Lounge)
Powerline 3 > Switch > Devices
How the heck is all of that SUPPOSED to be connected?? I rent, so I can't be trailing network cables all over the place and the Powerline adapters are fine for what I need them for. I just never know if all of that is connected the right way around, because my HomePods are constantly disconnecting and my cameras keep doing the same etc etc.
I just want to put all this to bed!
Thank you
Office:
Kitchen:
Lounge:
Upstairs (Office)
Downstairs (Lounge)
Thank you
