I just got a Thermaltake Commander C31 case and it has 2x200mm fans on the front. These are connected to a weird addressable RGB controller on the back of the case. And fans on the front are connected to this controller with weird 6-pin connectors. The problem is, I can control the RGB function, sync it with AURA and everything (btw my mobo is ASUS MAXIMUS XI HERO) I can't control the speed of the fans and it's very, very noisy.
What can I do?
Should I buy 2 new 200mm fans with both RGB and PWM controls?
Should I DIY the connectors with some soldering work?
What would you suggest?
What can I do?
