Question How to clean Wireless Earphone connector pin
Jun 10, 2019
Hi,
My right earbud is not charging, due to maybe the corrosion/carbon. See below, the top right connector. How can I clean it and to make the charging work again or is it seems to be damaged? Thanks
lu2SF_oQ5mHowIXGiP8BmXTM_TlrCHRw7VX0KhENjkZ2mqDzljdZuor4GzOm0GjN1r0YgqTLqO_-uU33RN4HEKB8yGTYr4SwMvEoeu5bylldoFuWRucu--Z7VM8LE4_y6_cSFsVb4zz5PUz5_pdDaz7FS7t_W8BPnl9RAPp6QcYSE-jbhhq2QzwyNDlgdoQPKx0jBvtxj-yX6pGsTHSi4FZyOuZyi9DUB0buWBmV0TwLdLYsSjApvNjqM1RUgILtmpnIz8yQ_ZUS6AzUAGe7TV6GnCBYRDz3EqPokYZ8B1WVurWU6qX3tMlLzW0NOfYCnYeQ-Kv6F1SycJdNC6PvrKavfZVrNBDP913vCZX3cDQBf7TdQwKD9chCef1p-IWYV2Jj8r831S9aJogJHMhNFs3YOxUXVUB05m4cvYAf-VWSOE82r_t0o50jUcNCM_okTFX4cuMbt46UUpWR5xL34KhrU6GO-FXLlhho2_dL9GPrrAs0d70HZeWrSl1yZ2Gu_1ob_ZKflEozezMl1Olg0aCLrEk7hR7BaozvniCcl7ebaSmp3OJcFdRgLVhdPGNWz4RR282-pejvBT3FYY3q5rSqYVwD0zjTQzqOiHvRCniphqLefy8myzN4UvRaeGB8diYcEMh3KKWiJnvmw5B9iNMvVS0uUVw=w1666-h937-no
You need to upload the image to an external image host like imgur. Then post the link here.
I use actual contact cleaner on my audio connections. Obviously that won't fix a damaged part.
