Hey everyone
I'm trying to connect two routers and create a subnet but failing due to a little knowledge but no real understanding!
I've read the ultimate setup thread loads of times but can't get my setup to work. Can someone please help?
Here's the setup I'm trying to build:
Internet -> Master ADSL modem/router (No NAT, no DHCP) -> Slave cable router (NAT, DHCP)
I want to connect 3 Xboxes to the master router with external IPs to avoid the whole "moderate/strict" NAT nightmare. Then I'll connect everything else (PCs, Macs, wireless devices etc) to the Slave router which will assign IP addresses and do the NAT thing. Both routers are Netgear N150s (master is ADSL, slave is Cable).
Here's what I've tried so far:
Master router:
All IP addresses supplied by ISP
Internet IP: xxx.68.160.143
DNS: xxx.xxx.3.xxx and xxx.xxx.6.xxx
Router IP: xxx.68.160.142
Subnet mask: 255.255.255.248
Gateway: xxx.68.160.143
DHCP disabled - all connected devices are given external IPs in range xxx.68.160.137 - xxx.68.160.141
NAT disabled
Slave router:
WAN port on slave connected to LAN port on master
Internet IP: xxx.68.160.??? (should this be the 142 address of the master router?)
DNS: xxx.xxx.3.xxx and xxx.xxx.6.xxx (or the address of the master router?)
Router IP: xxx.68.160.137 (one of the external IPs?)
Subnet mask: 255.255.255.0 (is this right?)
Gateway: xxx.68.160.??? (should this be the 142 address of the master router?)
DHCP enabled: but issuing IPs in what range?
NAT enabled
Anyone who can solve this will be rated 'network genius'! 😀
Thanks
Mike
Master router:
NAT disabled
Slave router:
NAT enabled
Thanks
Mike
