Hello,
my keyboard (Roccat Isku fx) just broke and I've decided to use the RGB panel from the keyboard. It has a 5-pin connector and I'd like to connect it to my 4- pin connector on my motherboard. Is that possible?
Unless you know the precise pinout of the 5pin, and compare it to the 4pin, and make appropriate adjustments then no you cannot use it, attempting to use it would be a very bad idea.
