[SOLVED] How to fix BTHUSB Error
Nov 18, 2021
Hi
I'm using a DELL Inspirion 5491 laptop with Windows 11. My Bluetooth driver disapper time to time for about 2-3 seconds. Following event is there with a warning. Hope someone could help me to resolve this issue.
Log Name: System
Source: BTHUSB
Date: 11/18/2021 12:31:02 PM
Event ID: 7
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
A hardware error occurred. The event contains the vendor-specific error code.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="BTHUSB" />
<EventID Qualifiers="32773">7</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-11-18T07:01:02.1883503Z" />
<EventRecordID>8882</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="15432" />
<Channel>System</Channel>
<Security />
</System>
<EventData>
<Data>
</Data>
<Binary>000000000100000000000000070005800C0000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Hi. I have the same Laptop. Mine did the same thing with bluetooth driver after updating windows 10 and intel drivers from windows update this week. i got in device manager and rolled back the Intel Wireless Bluetooth Driver to Version 21.110.0.3 - dated 6/25/2020. the problem was resolved immediately.
I'm not sure if you can roll back after a windows 11 upgrade. But you can probably still find that driver on the dell support site - or from intel if not. Good luck. I'm sure a better bluetooth driver will fix it if you can find it.
I run an IT consulting company. We run in to these kinds of issues with recommended drivers on the windows update site pretty often.
Reactions: Colif
