So i had a vhs tape and decided to convert it to an mp3 file but because the tape was old the audio was crackling even when we put it in the vhs player, is there and way i could reduce or get rid of it? here is a sample
Well first off, if these are important recordings to you, find some place where they refurb VHS to perfection.
But yes, there are software available just for the purpose, may even be freeware, u will have to Google, be aware of downloading malware. vcdhelp.com is a good place to start. You will not able to completely rid of it, there are cons of applying too much correction.
