So I have the following problem:
When I play that new just released game (Call of Duty Warzone) I first start my match off with a decent FPS, but once I am about to land on the map and the buildings start rendering in, I get a massive FPS stops on like every 5 seconds for 1 second and that goes on for the rest of the game (especially whenever I move my mouse), but also without too big of a movement.
It is also worth noting that I am a laptop user so I don't have any upgradeability options, so I would appreciate any help that evolves not having to upgrade my specs.
Here are my laptop specs:
CPU: i7-8750H @2.20GHz
GPU: Gtx 1050 Ti with Max-Q Design
RAM: 8 GB
VRAM: 4 GB
HDD: 1 TB
If any other specs are needed than let me know.
I am not 100% sure if the lag is caused by slow rendering issue, I just really suspect that. If You have any other idea, why I get massive FPS skips, than please let me know.
If there isn't anything I can do about the issue, then also please let me know. Although as I already said, I don't have many upgradeability options, I may be able to get a SSD if that is needed.
All that being said, any support I can get will please me, so any of your help would be helpful.
RAM: 8 GB
VRAM: 4 GB
HDD: 1 TB
