Hi, got new PC. Core i5 12400F and AsRock H670 Steel Legend board. I updated BIOS to the fresh 11.04 and ran popular CinebenchR23 CPU test and was surprised. While my single core result was completely normal as expected (1710-1725), CPU's multicore performance is very low (below 10000 instead of 12000). I found out that 6 cores work only at 4GHz max instead of 4.390Ghz (while 1 core works as intended).
AIDA64 helped me to see what is going on:
Max Turbo Boost Multipliers 1C: 44x, 2C: 44x, 3C: 42x, 4C: 42x, 5C: 40x, 6C: 40x
It means 1-2 loaded cores work at max speed, 3-4 cores at 4.2GHz and 5-6 loaded cores at 4GHz.
So I rebooted, opened BIOS. Found OC Tweaker -> CPU Configuration -> CPU P-core ratio -> Per Core. But I could not increase 42x or 40x multipliers, I could only decrease it! And set a value between 8x and 40x. I tried all options in BIOS (Auto, all core, per core, specific per core). So what is the problem, and can I fix it somehow?
P.S. Hyper-Threading is enabled obviously, so I ran test on 12 virtual cores.
