[SOLVED] How to fix the Sound on my Win 10 System?
werner_eksteen
17
After the new windows 10 update my sound stopped working. At first there was a problem with my drivers which I fixed. Now the drivers seem to be working but I still don't have any sound. I can't play a test sound and it says everything is working, but it doesn't.
If I run Media Player Classic it gives me the followin error.
LAV Splitter Source (internal)::Audio
LAV Audio Decoder (internal)::Output
Audio Switcher::Out
Media Type 0:
Audio: IEEE Float 48000Hz 6ch 9216kbps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: MEDIASUBTYPE_IEEE_FLOAT {00000003-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 24
cbFormat: 40
WAVEFORMATEX:
wFormatTag: 0xfffe
nChannels: 6
nSamplesPerSec: 48000
nAvgBytesPerSec: 1152000
nBlockAlign: 24
wBitsPerSample: 32
cbSize: 22 (extra bytes)
WAVEFORMATEXTENSIBLE:
wValidBitsPerSample: 32
dwChannelMask: 0x0000060f
SubFormat: {00000003-0000-0010-8000-00AA00389B71}
pbFormat:
0000: fe ff 06 00 80 bb 00 00 00 94 11 00 18 00 20 00 þÿ..»....... .
0010: 16 00 20 00 0f 06 00 00 03 00 00 00 00 00 10 00 .. .............
0020: 80 00 00 aa 00 38 9b 71 ..ª.8q
Media Type 1:
Audio: PCM 48000Hz 6ch 4608kbps
AM_MEDIA_TYPE:
subtype: MEDIASUBTYPE_PCM {00000001-0000-0010-8000-00AA00389B71}
lSampleSize: 12
cbFormat: 40
WAVEFORMATEX:
wFormatTag: 0xfffe
nChannels: 6
nAvgBytesPerSec: 576000
nBlockAlign: 12
wBitsPerSample: 16
wValidBitsPerSample: 16
SubFormat: {00000001-0000-0010-8000-00AA00389B71}
pbFormat:
0000: fe ff 06 00 80 bb 00 00 00 ca 08 00 0c 00 10 00 þÿ..»...Ê......
0010: 16 00 10 00 0f 06 00 00 01 00 00 00 00 00 10 00 ................
Media Type 2:
AM_MEDIA_TYPE:
lSampleSize: 24
cbFormat: 40
WAVEFORMATEX:
wFormatTag: 0xfffe
nChannels: 6
nBlockAlign: 24
wBitsPerSample: 32
dwChannelMask: 0x0000003f
pbFormat:
0010: 16 00 20 00 3f 00 00 00 03 00 00 00 00 00 10 00 .. .?...........
Media Type 3:
AM_MEDIA_TYPE:
lSampleSize: 12
cbFormat: 40
WAVEFORMATEX:
wFormatTag: 0xfffe
nChannels: 6
nBlockAlign: 12
wBitsPerSample: 16
pbFormat:
0010: 16 00 10 00 3f 00 00 00 01 00 00 00 00 00 10 00 ....?...........
I've tried every fix I could find online but nothing seems to work. If anyone has a solution I would really appreciate it.
First the simple question. Are the speakers muted?
When you run any type of audio program do you see modulating green bar levels in the Sounds Property Window?
-Wolf sends
I tried reinstalling the new drivers. Still no change. I also turned on all my seeing if windows might fix it through the troubleshoot but it doesn't pick up anything. I changed output devices and ports. No change. The test sound still doesn't want to play and it isn't muted. My drivers were working fine a week ago and suddenly it doesn't work. Could it be that my Sound Card has stopped working? The PC is 11 years old.
Since the motherboard doesn't natively support Windows 10, your best bet would be to try the drivers direct from Realtek.
Realtek ALC889 Chip Windows 10 64-bit Drivers
-Wolf sends
Sorry. Not trying to spam this but I really don't know what to do anymore. I tried troubleshoot again after enabling a few things and this is the results.
6Audio services not respondingNot fixed
Restart audio servicesCompleted
Both the Windows Audio and the Windows Audio End Point Builder services must be running for audio to work correctly. At least one of these services isn’t responding.
Potential issues that were checked
Audio enhancements didn’t loadIssue not present
One or more audio service isn't runningIssue not present
Both the Windows Audio and the Windows Audio End Point Builder services must be running for audio to work correctly. At least one of these services isn't running.
6Audio device is disabledIssue not present
The audio device you selected is currently turned off in Windows.
Device state
State information about the audio device.
State:Enabled
Status code:1
Help link:
Audio device mutedIssue not present
Audio can't play if the device is muted.
Audio device isn't set as defaultIssue not present
The default audio device is usually used to play or record sounds on your computer.
Audio format not set to defaultIssue not present
The speaker, headset or headphone is unpluggedIssue not present
An audio device must be plugged in to play or record sound.
It's possible that the audio chip has failed in the motherboard, but it'd be the first time I'd heard of something like that. Your best bet at this point would be to attempt to roll back to Windows prior to the update that knocked out your audio. If you can successfully roll back and get your audio working again, then we're pretty sure it was something in the update that killed it. If it's still not working after the roll back, then it's possible the chip failed and a sound card purchase (or system upgrade) would be in order.
-Wolf sends
Rollimg back did not work unfortunately. I don't know what else I can try. Restarting the services doesn't work either. Any other suggestions? The motherboard has been giving problems lately.
If there are no other solutions, what motherboard would be a good replacement and cpu?
True but there are other functions of the board not working anymore. Such as sata ports not picking up my drives. Also the Cmos keeps resetting. I mean it's been 10 good years, but it's probably time.
What external USB adapter would work? Don't you still need a sound card gor that to work?
My headphones are using a USB port but not working?
Besides looking for a new board for the old one you might just look into some external sound solution. (Either some internal PCI or PCIe card or external USB adapter.)
For a new platform it would mean new board, CPU and RAM.
