[SOLVED] How to fix wire in Logitech G430?
Dec 23, 2018
9
I have a Logitech G430 and the wire is coming out of the box with the mute button and volume control. The box does not seem to have any screws to take it apart. Anyway to fix this?
Split the box open with a knife and a spudger, re-secure the wiring, glue the box back together.
Otherwise, replace the headset....they are under $50.00 (US), and just aren't worth spending much time on to repair them.
