[SOLVED] How to know if to much thermal paste?
Joni1566
21
Hello everyone.
I just finished a new build and everything works great.
But I read about thermal paste and why you shouldn't use too much.
My question is how domi know if I used too much after finishing the build ? It's hard to get a direct look inside the PC as for all the comments.
It is worth mentioning that I played some intensive game and used 100% CPU for about 2 hours straight and in all that time the CPU temperature was at max 60+-
Can this be a tell the the thermal paste is in good amount as the temperature is in the safe zone?
If not is there any other way to know?
CPU - rayzen 5 5600x
Thank you.
60 is very good on Ryzen. My Ryzen 5 3600 can get up to low 70s in cinebench under load, that's with a tower cooler that has 2 120mm fans attached to it. For thermal paste, usually you just want a pea sized dot on the middle of the cpu. That's usually enough.
Hello everyone.
Thank you.
Looks like you have right amount of TIM, those temps are very good.
Latest posts
