[SOLVED] how to turn non surround speakers into stereo surround
harleyryan41
I have bought a pa system that has a big sub and two big speakers. They aren't surround (i mean left and right separated) but I now want to use the system for my computer and would like to have left and right side sound designated to each speaker. is there any hardware that would allow me to do this. Thanks!
Not sure why you had to explain the speakers being separated because surround means more than 2 separate speaker box setup, ie 5.1 ~ two fronts, two rears, centre & sub. Not that a single speaker entity could be a surround speaker.
PA amplifier that meets the wattage and ohm requirement for these speakers and sub should do.
Does the sub connect via coax or speaker wire?
So essentially what you mean is that you want a pair of mono speakers to work in stereo? What kind of PA system is this? Make and model?
If they are active, they should work in stereo..
